Joel..... ...ah yes, the 8-volt fix for hard starting. IT DON'T WORK on 6-volt 8N gennys. Why? 'cuz basic battery theory 101 sez ya gotta charge a battery with more volts than the battery is. This means an 8-volt battery needs about 10-volts to charge it. Understand that concept? Unfortunately, due to the way the 6-volt 8N's genny is designed, you can't gitt 10-volts outta it. Some claim you can "jimmie" the contacts in the squarecan voltage regulator to charge an 8-volt battery, NOT SO. Yes, there are some tractors out there that very successfully charge 8-volt battery, but the 8N-genny won't and can't. Your battery dealer is semi-correct, yer genny ain't puttin' out enuff VOLTS, not amps; but the results are just the same. Yer runnin' round on a discharged 8-volt battery. Me? I'd gitta good 6-volt TRACTOR BATTERY. I recommend the 6-volt batterys sold by (byte my tongue) John Deere dealer. They are heavier duty than Die-Hards (which die eazy) And re-polarize for POSITIVE GROUND. (iff'n you don't know how to re-polarize, ask) And then I'd fixx yer rusty old electrical system. Brand NEW one-ought (1/0) thick as yer thumb battery cable down to the starter solenoid. Then a NEW 11-in flatbraid ground cable bolted to one of yer steering box tranny bolts. And finally, un-screw yer 8in starter bolts about 1/4" gap and wirebrush between the starter plate and the tranny mounting hole. Understand? Your 6-volt starter motor will ZING. Then iff'n you still have starting problems, ask..... ...Dell, yer nitely battery lecturer
