Order Ford 8N Parts Online
8N proofmeter
robshicla
04-26-2007 14:48:43
Where does the proofmeter line go to on a 1950 8N? I assume its an early model 1950 due to the front mount distributer and 4 speed transmission.(The serial # is worn off) It has the big round hole on the bottom of the dash panel for the proofmeter. I was told the line goes to the governor housing, but I did not see a place for it. Could someone send me a picture? Thanks.
CT8N
04-26-2007 16:38:06
 Re: 8N proofmeter in reply to robshicla, 04-26-2007 14:48:43
I have a front mount 1950? with a proofmeter. You may have to replace the governor or rear governor housing to hook up the proofmeter.
Ken Crisman
04-26-2007 15:35:15
I'm not positive , but what I've read so far the earlier 8n with front mount distributor didn't have the proof meter & the governor didn't have the hole for the cable . Someone either changed motors or the dash . I don't know how to put pics on here but if you email me I can send you more help . write to callj.j.s@verizon.net. Good luck & God bless , Ken
