Stripped a axle housing to hub bolt...
SCgoatfarmer
04-27-2007 10:51:26
Able to pull out left axle and salvage it. This side was missing parts and the fender cover fell right off once the wheel nuts came off.
Right fender cover screws will not come out. Going to get a bigger screwdriver this afternoon. However, what happens if they get so buggered up I cant get them off? Drill the screw out?
Any suggestion on the axle housing screw to hub that is stripped out? I can take a hacksaw and cut the head off but it will still be bolted in. Will have to be drilled out too?
bizkit
04-27-2007 20:05:24
 Re: Stripped a axle housing to hub bolt... in reply to SCgoatfarmer, 04-27-2007 10:51:26
the key words here my freind iz smoke wrench and vice grips they work wonders
Tool Kat
04-27-2007 12:29:28
Not sure what a fender cover is. In the back of the IT manual is an exploded diagram of the axle and brake system with numbers. Let us know what numbers you are referring to, so we know what you need.
