Order Ford 8N Parts Online
where do I jack the rear right of an 8n
alaskenus
04-30-2007 12:50:16
I just bought an 8n and have no idea where to place a jack, just blew the rear tire out and need to replace.....help
dan hill
05-02-2007 00:52:02
 Re: where do I jack the rear right of an 8n in reply to alaskenus, 04-30-2007 12:50:16
Get a HiLift jack and some wood blocking.There are some import copies of the HiLift, dont mess with them..
Indiana Jones
04-30-2007 17:09:40
I used an engine hoist and wrapped chains around the trumpet to lift. Then put wood blocks underneath.
Dell (WA)
04-30-2007 13:30:48
alaskenus..... ..I always jack under the diffy, and then jack-stand the necessary axle trumpet where necessary. Gittin' the 300# rear tire off'n ain't eazy so you want the tire just clear of the ground.
Tip: even iff'n its flat, loosen yer lugnuts and drive yer tractor in figger-eights to loosen the rusty stuff. You won't hurt yer tire. 'course you could pumper full-o-air and that will generally last longenuff to drive in figger-eights. Iff'y you don't figger-eights, yer gonna be cussin' ..... .pottymouth Dell
Tool Kat
04-30-2007 13:02:32
Right under the right axle housing near where the fender bolts on.
HTH
Ramrod
04-30-2007 13:05:31
 Re: where do I jack the rear right of an 8n in reply to Tool Kat, 04-30-2007 13:02:32
...and get a jack stand under it before you start working on it. Harbor freight has some good big, tall jackstands that work just fine.
