Order Ford 9N Parts Online
ford 9n oil pressure
daryll litten
05-01-2007 07:22:12
my 9n has no oil pressure on spring start up after setting this winter, has always been slow to build pressure on start up,and drops to about 8lbs when hot,any ideas? ran it on idle several minutes.
TheOldHokie
05-01-2007 08:18:21
 Re: ford 9n oil pressure in reply to daryll litten, 05-01-2007 07:22:12
A couple minutes at idle with no oil pressure probably made your rebuild decision a lot easier. Especially if the oil pressure was spotty to begin with. Prime pump and fill with a SAE 40 or heavier and see what you get.
TOH
A. Bohemian
05-01-2007 10:59:28
 Yow! in reply to TheOldHokie, 05-01-2007 08:18:21
Quote: " A couple minutes at idle with no oil pressure probably made your rebuild decision a lot easier."
Yea, verily, thou hast said it, TOH.
souNdguy
05-01-2007 07:26:37
Try to prime it. remove the big oil pressure relief plunger ont he front of the engine and dump in some thick gear oil.. slap it back in and start rolling the egine over fast.
Also.. What weight oil you running?
I think if you are running 30.. it may be time to try 40 or 50 ( or 60 )
Soundguy
