Throttle problems
Redtail
05-01-2007 10:52:27
I wonder if anyone can help me with a throttle problem. I have a side mount 8N and when the tractor get under load, the throttle drops down - i.e. the handle on the dash flops down like it doesn want to stay in one place. I see a spring at the base of the throttle linkage and ot looks okay tho cant really get to it too easy as I have a loader on. Any ideas??
Redtail
05-01-2007 14:52:46
 Re: Throttle problems in reply to Redtail, 05-01-2007 10:52:27
thanks guys, I took off the hood to replace the radiator recently. My hunhc is that I knocked that bb out of there or soemthign when I did that.
Greg
GAJIM
05-01-2007 18:10:14
 Re: Throttle problems in reply to Redtail, 05-01-2007 14:52:46
Redtail: I had the same problem last year and I had a missing governor compensating spring. I installed a new governor compensating spring and the problem went away. GA Jim
souNdguy
05-01-2007 12:36:08
NO CORK FRICTION DISC... the 8n uses a quadrant and handle that has a little BB in it to rub across.
Lots of things happen.. the bb gets flattened.. or falls out.. the quadrant becomes worn.. or the spring down there becomes loose.
BB can be replaced if you work at it. The quadrant can be built up or re-gouged.. a dremel tool helps.. or a solder iron.. or brassing rod.. etc...
Soundguy
Ramrod
05-01-2007 14:46:17
 Re: Throttle problems in reply to souNdguy, 05-01-2007 12:36:08
Thanks fer watchin my back Sounder.
Ramrod
05-01-2007 12:04:30
There is a cork friction disk under the throttle disk on my NAA. I think your 8N will have one too. It is adjustable with a castle nut and cotter key, but my guess is that it's gone.
