Need starter help
reddogge
05-03-2007 05:49:35
third party image
I unloosened my starter bolt to clean the gap between starter and housing (works great now) but now I have a gap between starter and housing you can put a penknife blade in. I don't think that is good.
I have a strange arrangement of one bolt and one threaded rod holding it on and can't figure out why the rod is there or how to get it to tighten up.
K.LaRue-VA
05-03-2007 07:50:31
 Re: Need starter help in reply to reddogge, 05-03-2007 05:49:35
"(works great now)", I wonder how?
The first thing I would do is find a new set of starter bolts and figure out what the starter is hanging up on. Obviously, it should go all the way in. Cleaning the contact surfaces aint doing a lot of good if they don't touch each other.
The voltage to the spark plugs will jump a gap like that, but 6 or even 12 volts just wont work that way.
kl
reddogge
05-03-2007 05:50:42
third party image
Photo of rod.
souNdguy
05-03-2007 05:56:43
 Re: Need starter help in reply to reddogge, 05-03-2007 05:50:42
Looks like the prev owner of that N was a bit of a tinkerer. He probably lost one of the oem bolts and just used a piece of allthread and double nutted it to screw it in.
Allthread is grade 2 soft.. hope it didn't strip out.
I also see he cut some galvanized roofing tin and made a brush cover.. did a pretty good job of it too.
In any case.. i'd say you have a gap cause your bolts ain't tight.. and they aint tight for the reasons metnioned.
Pull that threaded one.. and see what it looks like on the end. Either get a new bolt.. or a new piece of allthread and go back in.. tap the starter with a mallet lightly to help it seat and then tighten her down appropriatly.
Soundguy
Soundguy
