Here is what I found after dis assembly
Pooh Bear
05-03-2007 14:38:06
Removed the steering arm. Removed the 4 bolts. Removed a cover plate. Then pulled the left side sector off.
About an inch from the gear, the shaft snapped clean in half. All the teeth are in fine shape. The box was plum full of thick gooey grease.
The gear has one big tooth and 8 little teeth.
So how do I fix this.
Thanks. Pooh Bear
third party image
third party image
Dunk
05-03-2007 17:38:00
 Re: Here is what I found after dis assembly in reply to Pooh Bear, 05-03-2007 14:38:06
Whooo, Weee...
Does that whole break look fresh?!?!
Yall took a lickin didn't you!! Glad you are still tickin'!! I had a right spindle break off one time, she just went 3 legged while we were plowing in 1st gear in soft dirt.
Messicks shows it avalible 3 to 5 days.
You are not going to like this...
New Holland 8N3526A SHAFT 3-5 days 364.41
Dunk
05-03-2007 17:41:09
 Re: Here is what I found after dis assembly in reply to Dunk, 05-03-2007 17:38:00
I may be confused about which side it was.
The one above is right side.
Here is left, go figure...
New Holland 8N3527A SHAFT 3-5 days 268.66
Pooh Bear
05-03-2007 18:09:47
 Re: Here is what I found after dis assembly in reply to Dunk, 05-03-2007 17:41:09
Someone here gave me a lead on a NOS complete steering box. I contacted the guy and he lives about 60 miles from me. We are working out the details of the deal now. Mostly do I pick it up or have it shipped. Waiting to hear back from him now.
Don't know what's more incredible. The fact that you actually found the part I need, or the cost of that part.
Thanks.
Pooh Bear
Dunk
05-03-2007 18:33:32
 Re: Here is what I found after dis assembly in reply to Pooh Bear, 05-03-2007 18:09:47
Good Luck Pooh!!
third party image Christopher Robin and I walked along
Under branches lit up by the moon
Posing our questions to Owl and Eeyore
As our days disappeared all too soon
But I've wandered much further today than I should
And I can't seem to find my way back to the Wood
