How to pack bearings before sure seal
Red
05-10-1999 17:46:51
Don't understand how you get grease to bearing ? My 2n has a steel plate between the retaining collar and the bearing . Not able to get to bearing to grease it. Or must you still break the retaining collar? How are bearings greased after sure seal is installed?
JerryU
05-10-1999 19:31:55
 Re: How to pack bearings before sure seal in reply to Red, 05-10-1999 17:46:51
My bearings did not have any kind of cover and the rollers were easily accessible to pack with grease. Wonder if that was an improvement on the 2N or some kind of an aftermarket bearing with an enclosed race?
You do bring up an interesting point that was made to me as well. I never thought about pulling the thing apart and pulling the sure seals to check the grease. Guess I figured they were sealed and low speed bearings.
Wonder if anyone has any experience with greased bearings after a period of time or a recommendation as to how often the seals should be pulled and the bearings greased?
