2N stumbles at high speed
brad knigga
05-06-2007 03:09:58
Hello,
My 2N has started to stumble a bit at high throttle. It idles nicely, but seems to miss a bit when I go to high throttle (like PTO speed).
Any ideas?
Thanks in advance.
RP-40-9n
05-06-2007 08:33:03
 Re: 2N stumbles at high speed in reply to brad knigga, 05-06-2007 03:09:58
brad, thats a classic sign of running lean. open the main throttle adjustment a full turn, and if that dont help, pull the main adjuster out and also the drain plug at the bottom of carb and blow a half can of carb cleaner in at top and let it run out the bottom. could be dirt or varnish in the carb. RP
A. Bohemian
05-06-2007 08:16:59
 One Idea in reply to brad knigga, 05-06-2007 03:09:58
Try to isolate the problem to one cylinder.
Take one wire off of a spark plug. You want to do things in a systematic manner, so I would start with #1. Start the tractor and try to make it do the stumble thing.
Problem no worse with wire removed from cylinder #1? You have greatly increased the probablilty that the problem is located in this cylinder or parts associated with it. Make a note of your findings.
Problem worse? The problem is not likely to be with #1 cylinder or parts associated with it.
In this case, make a note of your findings. Then, REPLACE wire #1 carefully. The idea is to only have one spark wire loose at a time so as not to mix up the firing order (1243).
Next, run the same test on #2. Then, if necessary, repeat on the other cylinders, always replacing the previously tested wire BEFORE removing the next one to be tested. Also, remember to make notes.
If the above procedure is run on EACH cylinder, and it is noted that the problem seems to get worse WHENEVER a spark wire is removed, regardless of which one, then the problem is very likely to be in parts and systems COMMON to all cylinders.
This procedure also has the added advantage that in the process of running it, the condition of individual spark wires, the arrangement of wires for correct firing order, etc., are easily checked. The idea is to keep your eyes and ears open.
Good luck and keep us posted.
Tn. Jed
05-06-2007 07:27:35
I just had a problem with my 49 8n and it was the weights in the distributer they were stuck and wern't advanceing the timing at higher rpms and made a horrible miss but thair may be something els to check 1st someone here should be able to help they are a great bunch
brad.knigga
05-06-2007 12:35:55
 Re: 2N stumbles at high speed in reply to Tn. Jed, 05-06-2007 07:27:35
I tried enriching the fuel mix... somewhat better. I then pulled the dist. cap and sprayed lubricant into the area, pretty well soaking everything. That seemed to help a great deal.
Thanks for all the suggestions!
jophn hunt
05-06-2007 05:51:09
i guess there could be few problem fould spark plugs are crapee in carb are sparkie jump from to lose wire ... something simply loose hot wire etc
