Steve..... ...IT AIN'CHUR CARB!!! keep yer ittchy-twitchy fingers away from them handy-dandy carb tweek'ems. Understand? Well gee, iff'n you think its a fuel problem, why not check yer fuel filters? Simple, eh? I'm not gonna scold you about not knowing that flathead 8Ns were last made in 1952 with the carb on the right side; or OHV Red Tiger engines were installed on 1953 NAA Jubilees with the carb on the leftside. Four sparkies is 4-sparkies, eh? Howsomevers, 30-sec runtime is usually a bad condenser. (time for tune-up kit, eh?) Usually, it takes about 3-mins for clogged fuel filters to empty out the carb and cause it to quit running. But don't discount WATER in the gas. Pull the carb drainplug and letter'pee in a qt-glass jar so you can visually inspect for water/foggy gas. Sometimes yer weaksister ignition switch will cut-out in 30-secs, but generally its a 15-min runtime quitter. Gott some ideas now? ..... ..respectfully, Dell, yer self-appointed sparkie-meister
