Bad news
ratropia
05-07-2007 10:58:13
49 8N My earlier post stated "blow by from the manifold gasket" Now in the day light I haved determined water sizzling out from the head gasket. Boy did I screw up with the MMO. Completly my fault not the product. I suppose this means a more major repair eh?
RP-40-9n
05-07-2007 12:39:07
 Re: Bad news in reply to ratropia, 05-07-2007 10:58:13
stop kicking yourself the extra quart had nothing to do with you blown H.G.notta-zilch ok? have fun n-joy while you learn. RP
Dan
05-07-2007 11:29:00
I still do not see how putting one extra quart of oil blew your head gasket. I would say it was a coincidence. Either way, replacing a head gasket is easy work.
Dan
Dell (WA)
05-07-2007 11:14:07
Ratzie..... .what is so intimidating about replacing the headgasket??? ($20, cheap). Eaziest done with hood removed by 2nd helper. My 9yo son helped me, he's now 25 and 2000mi away engineering at Wright-Patterson AFB Ohio. Check yer flathead for warp, don't know how? Takker into automotive machine shop where they check'em all the time and then mill the head flat ($20, cheap)..... ..Dell
ratropia
05-07-2007 11:29:30
 Re: Bad news in reply to Dell (WA), 05-07-2007 11:14:07
Dell, I appreciate your candid replies. I am going to try and replace it my self. Maybe your boy could help me I am in Hillsdale county MI. a little closer than you. ;>) As far as checking the flat head for warp. Do i take just the "head" or the whole engine? Sorry for the remedial question. But I don't know. What else should I do while I have it off? Also do you suppose my screw up with the MMO caused this? Or do you think it was going to happen enny ways? I know you don't mind read And I do not think I want to talk to your Ex ;>) So just a stab in the dark for my simple mind. Thanks Rick T.
Dell (WA)
05-07-2007 11:43:54
 Re: Bad news in reply to ratropia, 05-07-2007 11:29:30
Ratzie..... ...dang, must be slippin' in my descrptions. "takker into auto machineshop", meaning take just the cylinderhead into an automotive machine shop. They check cylinderheads for "warp" all the time. Its a very common occurrence with aluminum heads used on rice-rockets.
I could tell you how to use a "carpenters framing square" to edge across the head and look for light under the square edge, you see lite? its warped. And you can't un-warp it with hand tools. That is what a milling machine does. Maximum allowable "skim" is 0.060" (which is a lot)..... ...Dell
