Flow chart for troubleshooting side mount
kidd65
05-07-2007 11:53:04
In the archives I found a message from BG from a couple of years ago saying he (or someone) was going to do a flow chart for the 8N sidemount. I have searched all through the archives and have not been able to find one. Is there a flow chart for the sidemount like this one for the front mount?
http://projects.mergecomputer.com/ford%20tractors/Service%20Specifications/Servicing%20the%20Distributor/elec.%20diagnosis%20chart%20-%20front%20mount%20distributor.jpg
riverbendfarms
05-07-2007 15:31:51
 Re: Flow chart for troubleshooting side mount in reply to kidd65, 05-07-2007 11:53:04
Awesome shart.
That is so helpful.
Thanks for posting!
Phil (NJ,AZ,Sask)
05-07-2007 13:11:52
Kidd65, That is "MY" (Haniwork) Flow Chart for the Front Mount using "Just" the Ammeter, it is not that hard to use it for a Side Mount. Every 3 Amp Spec would be changed to >4 amps, and the physical device changes. I was going to do a VOLTAGE flow chart, for both, but just never got it done.
Is there any interest in a Voltage Flow Chart?
Phil,
Larry in GA.
05-08-2007 01:50:17
 Re: Flow chart for troubleshooting side mount in reply to Phil (NJ,AZ,Sask), 05-07-2007 13:11:52
Phil
There is all ways one like me out here that need all the help we can get. So a Voltage chart would be great. If you get an up date on the front mount let us know I all most to that point. that and HYD. pump then paint. Larry
A. Bohemain
05-07-2007 14:04:33
 Good Work! in reply to Phil (NJ,AZ,Sask), 05-07-2007 13:11:52
That's some gooood stuff there, Phil.
Mind if I use the url in replies? You'll get full credit; I just want it for "Sounds like it might be your points. Phil has a very useful flowchart HERE" type posts.
Phil (NJ,AZ,Sask)
05-07-2007 14:32:36
 Re: Good Work! in reply to A. Bohemain, 05-07-2007 14:04:33
A.Bohemain, Just wait as that is an early Version than what's on my computer (more Detail). That may have been posted for comments & then the drawing updated. I will try to post the full Drawing, updated.
You can use anything I post as your own.
Phil,
kidd65
05-07-2007 13:28:05
 Hey, Phil in reply to Phil (NJ,AZ,Sask), 05-07-2007 13:11:52
I can't get a very clear copy of the chart off the internet. Is there a clearer version somewhere other than where I was looking?
Phil (NJ,AZ,SasK)
05-07-2007 14:19:05
 Re: Hey, Phil in reply to kidd65, 05-07-2007 13:28:05
Kidd65
That is a very "early" version, and I don't Know
where you found it. Its done with ACAD12 and thats WIN98 not XP. I think I posted it "here" in 4 sections so it would print at 4X and you would just tape the sections together.
I still have the Acad drawing File, but I don't remenber how I converted it. I may have printed & then Scanned back in as MPEG.
I will see if my Win98 stuff works together!
kidd65
05-07-2007 15:58:34
 Re: Hey, Phil in reply to Phil (NJ,AZ,SasK), 05-07-2007 14:19:05
I found it at Brand X website at
kidd65
05-07-2007 13:15:58
Thanks, Phil. You've created a very useful tool for us dummies. I know just enough to get myself confused. Your flow chart un'fuses me.
I'm sure a lot of folks appreciate the time and effort it took to create the chart and they've used it but never took the time to thank you.
THANK YOU!
