New governor guts proof meter attachment
premie-farmer
05-07-2007 13:17:48
Thanks for all the help on my governor rebuild. As I said in my other post I had to end up getting new guts as I couldn't get the gear off the end to get the races off. When the new guts came in the proof meter connection wasn't on it so I tried the 3/4 roll pin as recommended it worked for about 5 mins then proof meter went to 0. Any chance the roll pin is spinning freely in the hole in the end of the proof meter? If so anyone have any idea what to do about it?
Hobo,NC
05-07-2007 17:54:41
 Re: New governor guts proof meter attachment in reply to premie-farmer, 05-07-2007 13:17:48
I have the correct pin email open.
Ramon
05-07-2007 14:30:24
My call is that is is spinning. However, I hope nothing was damaged as a result of this. You need to go back to Ford or one of our vendors for the correct adapter, if I am reading correctly as to the issue here.
