o oil presure at start up
oldfordNN
05-07-2007 14:34:19
Any ideas why my oil pressure would be 0 at start up and after 10-20 seconds shoot up to 45 psi cold? Dropps to 20 after warm up.
Dean
05-07-2007 15:11:22
 Re: o oil presure at start up in reply to oldfordNN, 05-07-2007 14:34:19
OldFord:
It sounds like your oil pump is loosing its prime and taking several seconds to reprime.
This could be caused by a loose or cracked pick up tube.
The lower pressure after warm up is due to your oil thining out as it warms up.
I recommend inspection of your pick up tube as it will likely fall off completely if it is loose or cracked.
Dean
