losing spark
roger mills
05-07-2007 18:06:11
i have an 8n that has been converted to 12 volt system the tractor runs good for about 1 minute then cuts off i have no spark after it quits i wait about 5 min and my spark returns and it will run again for a short period do i have something heating up that is causing this
Dell (WA)
05-07-2007 18:36:40
 Re: losing spark in reply to roger mills, 05-07-2007 18:06:11
Roger..... .there are 4-common runtime issues with the 4-nipple squarecan frontmount ignition system, and surprizingly enuff it happens whether 6-volts or 12-volts.
1) runs for about 1-min and quits; restarts in about 5-mins. BAD condenser. Sound like yer problem??? 2) runs for about 5-mins and quits; restarts in about 15-mins. Clogged fuel filters (3-filters) NOT yer stated problem, but could be. 3) runs for about 15-mins and quits; restarts in about 30-mins. BAD weaksister ignition switch. NOT yer stated problem, but could be. 4) runs for about 1-hr and quits; restarts after overnite cool-down. NOT yer stated problem, but could be.
It AIN'CHUR CARB!!! keep yer itchy-twitch fingers off'n them handy-dandy carb tweek'ems. Understand? Respectfully..... ....Dell
rp -40-9n
05-07-2007 18:36:15
it will most likely be the ignition switch, condensor or resistor. in that order. RP
