brake drums
pushman
05-08-2007 13:55:58
I was wondering how heavy a 2n"s brake drum is whan you pull it off.
Sean (TX)
05-08-2007 14:57:35
 Re: brake drums in reply to pushman, 05-08-2007 13:55:58
If you are talking about pulling the drum and axle. You have to pull them both at the sametime. I would say more like 75 pounds... Its a 2 hand job for sure...
pushman
05-08-2007 15:01:24
 Re: brake drums in reply to Sean (TX), 05-08-2007 14:57:35
Yep that is what I am talking about because I am going to put sure seals in.
Sean (TX)
05-08-2007 15:10:57
 Re: brake drums in reply to pushman, 05-08-2007 15:01:24
Sounds like ramrod...Dont know what he is talkng about. Way off on his weight guestament LOL Just did brakes sure seals bearings and the inner seals on mine. Not a tough job just dig in. Got the gaskets you need for shims?
Ramrod
05-08-2007 18:14:06
 Re: brake drums in reply to Sean (TX), 05-08-2007 15:10:57
hardly ever do... I was thinking NAA, drums come right off. Older tractors have one piece drum and axle? Didn't know that!
Ramrod
05-08-2007 14:00:19
Not heavy, unless you drop it on your toe. 8 or 10 pounds I guess.
dan hill
05-09-2007 03:12:20
 Re: brake drums in reply to Ramrod, 05-08-2007 14:00:19
There should be some flat head screws holding the drum on the hub.Dufus usually leaves them out.Loaded tires are a two man job.
pushman
05-08-2007 14:04:16
I was just making sure it wasn't to heavy before I got to far into the job. Thanks.
Ramrod
05-08-2007 14:14:33
 Re: brake drums in reply to pushman, 05-08-2007 14:04:16
Heavy part is wheel and tire. Be careful with that.
pushman
05-08-2007 14:16:53
 Re: brake drums in reply to Ramrod, 05-08-2007 14:14:33
Our tire are even fluid filled!!!!! !!
Bob Harvey
05-08-2007 15:20:20
 Re: brake drums in reply to pushman, 05-08-2007 14:16:53
Do NOT let that sucker fall on you !! I had a 12.4 x 38 'filled' JD lay me flat for 4 hours until my son came home and wrestled it off'n me...good thing he's a big lad !!
