Order Ford 8N Parts Online
8N won't start
Richard M. Clar
05-09-2007 13:59:21
Okay, here we go. I totally restored my 1948 8N about five years ago. We used it for two years and it sat idle for the last three years, outside and covered in a plastic tarp. I have since drained all old gas, added a new battery, coil, points and cap. She just turns over. What am I missing???
Richard M. Clarke
05-14-2007 12:07:48
 Re: 8N won't start in reply to Richard M. Clarke, 05-09-2007 13:59:21
The main problem turned out to be no ground to the distributor. I scraped and cleaned the mating block surface and sprayed with carb clean. Once everything was installed she started with a little help with ether. The water pump had dripped right where the distributor was. Needless to say, the pump has been replaced.
old
05-09-2007 15:42:22
Rich take if from one rich to another, use tranny fluid instead of the MMO and save your self a few bucks. Also I would put more then just a table sppon in, say more like a !/2 cup in each cylinder and let it sit till tomorrow, pull the plugs and turn it over to clean the cylinders and then put the plugs back in a try to start it, it will smoke for a few but that clears up fast. The tranny fluid will do the same thing as MMO but at less then half the cost
Sean (TX)
05-09-2007 14:19:07
Didnt mention if you checked for spark...Is it blue? Sitting that long you should clean all the wiring connections...
Danny in CO
05-09-2007 14:06:48
Richard,
It could be lack of compression because of stuck rings from sitting for 3 years. Check compression. It should be a minimum of 90 PSI. Next do a wet compression test (a little oil in each sparkplug hole before checking). If compression comes up quite a bit with wet test, probably stuck rings. Try putting about a spoonful Marvel Mystry Oil (MMO)in each cylinder each day for about 3 days. Then repeat compression test.
Also, will it fire on starting fluid?
Danny
Richard M. Clarke
05-09-2007 14:19:03
 Re: 8N won't start in reply to Danny in CO, 05-09-2007 14:06:48
Hello Dan
I haven't tried the ether yet nor a compression test. I need to find my compression tester now. Thanks
Richard M. Clarke
05-09-2007 14:18:43
Hello Dan
hahah
05-09-2007 14:04:22
you forgot to put new gas in
