I just don't get it......
Poot
05-11-2007 05:51:37
I finally had time to install the new starter drive on my '50 8N, but now, it only gives me a low "growl" when I try to start it. The battery has a fresh charge & tested. New cables, ALL connections are clean, bright, & tight, & the starter mating surfaces were wire brushed to a bright finish. I even wire brushed the starter bolts & I STILL don't get anything but the low growl. Is it time for a starter rebuild, or am I simply overlooking something?
DON TX
05-11-2007 19:30:14
 Re: I just don't get it...... in reply to Poot, 05-11-2007 05:51:37
You didn't mention 'big hairy chested 00' new battery cables. (%^)
DON TX
Poot
05-12-2007 06:53:36
 yep, did that........ in reply to DON TX, 05-11-2007 19:30:14
A "big ol' 'airy chested, thick as yer thumb" cable & a new 11" long flat braid.
Dell (WA)
05-11-2007 08:26:12
Poot..... ...ya done EVERYTHING electrical you can do. Iff'n yer starter doesn't turn yer engine and start it, then its time for mechanical inspection. Probably needs new brushes and polished copper-bars of the commutator.
Don't forget, to ears used to the zinging of 12-volt rice-rocket starters, the rumpa-rumpa of a 6-volt starter is scary..... ..Dell
Poot
05-11-2007 10:19:11
 Hey Dell......... in reply to Dell (WA), 05-11-2007 08:26:12
I'd be happy with the "rumpa-rumpa of a 6 volt starter". IF I can ever get there. I usta call this thing "Baby", but now she's gettin' more & more like a cranky ol' "Blue Haired" biddy out at the Menopause Meadows rest home!! :-{
john hunt
05-11-2007 06:17:41
check and see if you oil line might be touch the starter. that's most of the problem. anyway move the line away from that area just 1/4 or a 1/2 inch and see what happen ...
oh yeah it would do it when I turn my starter over, and stop when it off....
Poot
05-11-2007 06:28:14
 Thanx, John....... in reply to john hunt, 05-11-2007 06:17:41
I never thought of that. I'll go check it right now.
