Order Ford 8N Parts Online
8n 6 volt starter
rainyweekend
05-12-2007 03:12:19
Well the 6 volt starter finally bit the dust. looks to me that the brushes and bendex gear need to be replaced. I have already converted the 8n to 12 volts right up to the starter. Question: do I have the 6 volt repaired, can I have that one changed to 12 volts, or do I buy a new 12 volt?
Ron
Ramrod
05-12-2007 04:47:09
 Re: 8n 6 volt starter in reply to rainyweekend, 05-12-2007 03:12:19
Repair it at a good starter and alternator shop. He can convert it while he's in it by changing the field to 12v, and have him dip it in the solvent tank and strip it clean, then you can prime and paint it and it will be new again.
rainyweekend
05-12-2007 05:06:59
 Re: 8n 6 volt starter in reply to Ramrod, 05-12-2007 04:47:09
Thanks that sounds like the less expensive way to go. do I have to replace the solenoid that is on the 6 volt with a 12v?
Ron
Dell (WA)
05-12-2007 07:31:11
 Re: 8n 6 volt starter in reply to rainyweekend, 05-12-2007 05:06:59
Ron..... ...NO, yer solenoid don't care, 6-or-12 volts, don't care positive-or-negative ground. Isn't that amazing???..... .Dell
rainyweekend
05-12-2007 13:30:48
 Re: 8n 6 volt starter in reply to Dell (WA), 05-12-2007 07:31:11
If it dosn't care i don't care! thanks Dell
