sure seals won't fit in
pushman
05-12-2007 14:17:26
The sure seals we bought will not fit in. When we try with a 3 in piece of pvc pipe to pound them in one side will slip in and the other will be stuck. Any hints on how to get them in is thankfully taken.
pushman
05-12-2007 16:00:32
 Re: sure seals won't fit in in reply to pushman, 05-12-2007 14:17:26
yea we did grease the bearings. I read it on this website before as everybody here is great help. Thanks for the comments.
Dan
05-12-2007 15:03:12
I found the 3" pipe did not quite allow it to sit on the flat landing of the sure seal, it rode up a bit on the cone. I beveled the end of the PVC pipe on the sure seal side a tad with my Dremel tool so it would sit flush with the flat landing on the seal. This allowed me to "tip" the pipe to the one side that was giving me trouble going in and apply more pressure to that side. Also - you can't be gentle with these or you will never get them started.
BTW - did you make sure to grease your bearings good before installing the sure seal?
Good luck,
Dan
ZANE
05-12-2007 14:25:31
You will need to grind the outer leading edge of the seal to a taper to get it to start. Something less than 20% taper or about 3/16 inch back from the edge.
Zane
