Order Ford 8N Parts Online
Flow Chart_ 8N Side Mount
Phil (NJ,AZ,Sas
05-13-2007 00:34:50
Link
This is the Side Mount Flow Chart, the ammeter must read ZERO with the points OPEN.
The 4 amp spec is based on OEM coil that has BAT & Dist terminal markings.
The Current Replacement, has + & - markings, may be lower or higher.
Hope this Helps,
