Hot coil
RJ
05-11-1999 14:42:03
My 9n has been converted to a 12 volt system. I just installed a new carb, alt, dist cap, points, coil, and condensor. The coil is too hot to touch. I am sure I need a resister. What type do I need and after it is installed, how much voltage should be at the coil primary terminal? Also, how do you tell if a governor is bad?
