AL..... ...you write..... ."I haven't replaced the coil because it showed good according to my tester. The resistor also tests good. Could the coil be too weak to start but show ok on the meter?"..... ..yep, ain't NO ohm-meter tester gonna find a BAD frontmount squarecan ignition coil. You need to make a "calibrated" sparkie tester from enny old sparkie you have layin'round. Bend the side electrode out for a full 3/16" gap. Clamp the sparkie tester to enny convinent engine bracket. Plug enny sparkie wire to the tester. Now try and start yer engine while watchin' yer calibrated tester for blue-snott sparkies. Wimpy yellowish-orangeish poor excuse of a sparkie ain't gonna start yer engine. For reference purposes, my eazy starting 6-volt 8N will jump a 3/8" gap. Change yer sparkies AGAIN. AutoLite 437's are good, gap = 0.025". All yer puttzin'round had FLOODED yer sparkies with INVISIBLE contaminates and them lazy sparkies gonna dribble down the center electrode instead of jumpin' the gap and sparklin' yer engine. Don't throw yer sparkies away, re-cycle them by letting a HOT RUNNING ENGINE clean them, one-atta-time. And save them for the next time you flood. (and there will be a next time)..... ...Dell, yer self-appointed sparkie-meister
