Order Ford 8N Parts Online
proper fluid for 8N
rainyweekend
05-15-2007 11:02:41
Ok I know i saw the proper transmission, rear end, and lift oil for my 1948 8n, from NAPA , but i'll be damm if i can the MSG that was posted. anyone have the NAPA number?
Thanks Ron
rainyweekend
05-15-2007 13:46:20
 Re: proper fluid for 8N in reply to rainyweekend, 05-15-2007 11:02:41
Thanks Guys i'll put that napa number in my 8n folder. I don't know what i would do without this site
Ron
TooTall
05-15-2007 11:50:41
I thought GL-5 was hard on the brass?
souNdguy
05-15-2007 12:21:30
 Re: proper fluid for 8N in reply to TooTall, 05-15-2007 11:50:41
It can be hard on yellow metal if it has not been formulated to not damage them.
there are a few manufacturers that make a gl4/5 oil that claims to be ok for yellow metals. otherwise I look gor a gl-3.. which is probably what TSC carries marked for ford.. etc.
Failing that.. gl-1 seems to work fine too.
For the person looking fro a napa number.. 65-205 = 5g pail.
Soundguy
Bruce (VA)
05-15-2007 11:45:27
For future reference, it's in tip # 3 of the 50 Tips:
Link
NAPA part number 65-205
That's the thick stuff.....lots of folks like the Ford 134d for year around use.
gahorN
05-15-2007 11:15:27
Ordinary GL-1, GL-2, GL-3, GL-4, or really common GL-5 (available almost anywhere and as recommended by the IT FO-4 manual for N-Fords) will work.
