fuel flow problems on JUBILEE
riverbendfarms
05-17-2007 09:56:15
My Jubilee runs great for 10 minutes then under load it wants to die.
I have determined a fuel flow problem.
The fuel lines pours like "a cow pissing on a flat rock" up to the carb,
then after the carb fuel flows ok for 30 seconfds then trickles.
I cleaned out fuel filter and will now dissasemble carb and clean it out good.
Possibly a clog somewhere? Has anyone come across this problem?
Any clues to speed up the process???
Thanks!!
RP-40-9n
05-17-2007 13:24:26
 Re: fuel flow problems on JUBILEE in reply to riverbendfarms, 05-17-2007 09:56:15
pull out the main adjusting needle on the carb, and the drain plug at the bottom of carb and blow a half can of carb cleaner in at the top and let it run out the bottom. RP
duey
05-17-2007 10:14:27
And is this with the fuel cap ON the tank or OFF?
Try the "flow check" with the cap OFF and if it does not slow down, it is a vent problem... mud daubers or something....
Good Luck duey
riverbendfarms
05-17-2007 10:17:07
 Re: fuel flow problems on JUBILEE in reply to duey, 05-17-2007 10:14:27
Hey,
Thanks for the tip.
I never thought of that but it was with the cap on that the fuel flowed fast, it just flows fast up to the inlet to the carb, after i put the line back on the carb it trickles.
I cleaned the inlet filter so it must be a clog in the carb somewhere.
thanks....
Dell (WA)
05-17-2007 10:05:14
Riverbend..... .you do know the carb elbow is ALSO a clogg-able filter, don't you???..... ..Dell
riverbendfarms
05-17-2007 10:10:01
 Re: fuel flow problems on JUBILEE in reply to Dell (WA), 05-17-2007 10:05:14
Hi Dell,
Yes i know, as I have rebuilt before, so i did clean that one out real good, its just somewhere in the carb, so i'm cleaning it out right now so i'll check it tonight, it must just be a clog somewhere.
souNdguy
05-17-2007 11:56:03
 Re: fuel flow problems on JUBILEE in reply to riverbendfarms, 05-17-2007 10:10:01
Not much between the carb fuel inlet elbo an dthe carb bowl except a flaot needle and seat.. that tells you where to look.
soundguy
