rear end trouble
Ball Bearing
05-18-2007 05:48:58
third party image
Pic from P and P if I'm lucky. Found this crack in the housing which holds the driving pinion pilot bearing #4625. Any idea of what would have caused this and whether it will cause any future problems? Could have been there for 50 years, Thanks BB
Dean
05-18-2007 09:08:51
 Re: rear end trouble in reply to Ball Bearing, 05-18-2007 05:48:58
BB:
I do not see the crack that you are referring to in your picture but will say that this structure is the weak link in the N tractors.
N differential housings fail in this area so if yours is indeed cracked it is likely that it will fail sooner or later.
Dean
BALL BEARING
05-18-2007 13:54:13
 Re: rear end trouble in reply to Dean, 05-18-2007 09:08:51
third party image
THIS SHOULD HELP.
Ball Bearing
05-18-2007 05:53:04
 again in reply to Ball Bearing, 05-18-2007 05:48:58
third party image
I'll try again.
