Order Ford 8N Parts Online
Brush Hogs for Ford 8N
Rich
05-11-1999 21:26:55
I recently acquired a Woods Brush Hog and attempted to attach it to my 8N only to find that it touches the rear wheels when lifted with the 3-point hitch. Also, the PTO shaft is too long after attaching a PTO shaft enlarger and over-run clutch. Any suggestions on this problem?
bg
05-12-1999 16:35:43
 Re: Brush Hogs for Ford 8N in reply to Rich, 05-11-1999 21:26:55
Set the quadrant stop at the point just before the mower hits the wheels, cut the shaft off to fit.
Dave(Missouri)
05-12-1999 11:12:24
Rich, Check into buying some longer lower arms and anti-sway bars. I've bought them cheap at
a Buchheit's store near us or your local New Holland dealer will have them. Use a tape measure for center to center distances. They are easy to swap on and off. I have a 5' Junior Brush Hog for
my 8N and it's really heavy. Be careful.
its o.k. to.......Dell (WA)
05-12-1999 08:53:59
Rich..... .."shorten" your PTO shaft for your brush-hog with a hack-saw.....equal amounts both inner and outer shaft and plastic safety shield. It should be obvious which ends to cut, not the U-joint end (grin)
Most users with 5' brush-hogs generally have sufficent clearance from their rear tires. Most users use "anti-sway bars" from below the rear fender mounts to the lower 3-point hitch points on the mower to keep from "bumping" into the rear tires.
If you have a 6' mower, the eazyist answer would be to remount your rear tire out one "notch". Remember N-tractors are designed to have "adjustable" wheel spacing. Check your owners manual. Its really quite eazy to do.
As the self-appointed safety preacher, I am pleased to learn you have got the "religion" and already have an "over-running coupler".
Hope this helps, yours for safer tractoring..... ..Dell
