fuel flow problem solved......
riverbendfarms
05-18-2007 10:18:02
Thanks for the input guys!.
I got my fuel flow problem solved.
The Jubilee runs strong and i was actually able to rototill for an hour with no sputtering.
I pulled off the carb, and i think the needle valve was sticking because it was clean in there so i cleaned anyways, put it back together and it was running like a champ.
Still no luck on my 8N hydraulics but hopefully i can pull it apart this weekend and get it going.
Have a great long weekend!!!
Colin King
05-18-2007 13:09:17
 Re: fuel flow problem solved...... in reply to riverbendfarms, 05-18-2007 10:18:02
Hey, glad to hear you"ve finally got one of your ole girls running right!
Happy May Long to you! We"ve got another weekend to go before our much deserved long weekend here in the States.
Colin, Minnesota
Danny in CO
05-18-2007 10:43:32
River,
Did the needle valve have a neopreme (sp?) seat or was it all metal? If it had a neopreme seat, it may stick again. Mine does this occasionaly. I just tap the side of the carb and so far that has fixed the problem.
Good luck,
Danny
riverbendfarms
05-18-2007 11:15:21
 Re: fuel flow problem solved...... in reply to Danny in CO, 05-18-2007 10:43:32
Yes it did have the neoprene insert.
Thanks for the tip!
If it sticks again i'll just try tapping it instead of taking the whole thing off.
thanks!!!
Carl (NH)
05-18-2007 10:21:04
Well, I hope that's the final cure for that problem! Thanks for the update. I hope you can resolve your 8N hydraulics too.
Carl
