Some more information about gasoline: The volatility specifications (distillation, vapor pressure, V/L, drivability index) for all grades of automotive gasoline are the same for a given season. These specifications do change from season to season (summer to winter), so all gasolines are more volatile in the winter (to improve cold starting), and less volatile in the summer (to prevent vapor lock). The difference between grades of gasoline is the octane rating, which is the number you see posted on the pump. Due to the nature of high octane molecules compared to low octane molecules, premium gasoline tends to be more dense than regular gasoline. The low compression engines in the N series tractors should not experience pinging on regular gasoline, so buying premium for a N is a waste of money. AvGas is designed for aircraft engines, and the specs are different than for automotive gasoline. AvGas is generally expensive, assuming you can find it. An N tractor should not need AvGas to run properly. From a gasoline standpoint, the main thing to do to help the tractor start in the winter is to buy gasoline for the tractor during the winter. Do not use gasoline that's left over from summer (or even early fall, for that matter). If you have fresh gasoline in the tank and you still have problems starting, the solution likely is somewhere other than the gasoline.
