New Holland
Norman Rankin
05-18-2007 18:27:31
I have a 2000 New Holland TC25D Hydrostat tractor. I sold my 8N and bought this a few years ago. It has been a pleasure to use. I recently replaced the two 5/8" hoses on the hydrostat cooling radiator that is in front of the motor radiator. I have noticed that when the motor is running these hoses swell with pressure, and I am having trouble with these hose connections leaking. I felt that the hydrostat filter might be plugged so I replaced it, but the problem remains. I was told by the New Holland technician that they made these filters a smaller micron and so some have this increased pressure problem. I also checked the oil and noticed that it is foaming and white on top, and on the dip stick. This is a new thing, didn't notice this before. It has an automatic transmission New Holland oil they sold me for this that is number G 137. It seems very thick to me for a hydrostat drive, but what do I know. Any Ideas out there? I may put a car filter from autozone on it, but of course the technician recomends against it. He says I should but the New Holland retrofit kit with new high pressure hoses for over $130.00. I can't buy the older filter with a larger micron tollerance. I was told this is to protect the over $3000 hydrostat drive. Where's my old 8N?
Scott PA
05-19-2007 17:52:58
 Re: New Holland in reply to Norman Rankin, 05-18-2007 18:27:31
Ask your dealer to talk to their service rep for policy adjustment for the parts to put the updated lines on, they will need your serial# and hours from the meter, I would change the oil and filters if it looks milky because it will not flow though the filters fast.
ericlb
05-18-2007 20:02:49
first if it were mine no way would i put a car filter from autozone on a hydraulic system, 2 reasons 1 all filters are not created the same with regaurd to quality, second if the filter has pressure to it from the hydraulic system, a car filter may not be designed to take the pressure, i would get a manuel first and check to see what kind of fluid the factory put in the tractor then go from there,
