I am in the process of rebuilding my 8N transmission, which has a Sherman Combo installed. (First Time in the Tranny) Yes, I have the F0-4 manual.I have some questions... Since the Oil seal is in the Sherman and there is no longer a Bearing Retainer Shaft, should I bother to tear apart the Sherman to replace the oil seal if it's not leaking? Should I worry about checking the Oil/fluid level of the Sherman while I've got it sitting in the floor, and if so, how? How does one go about checking the Preload of the Main shaft? The counter shaft has a bolt that I can put the torque wrench on... but not on the main. In Smith's Sherman Install instructions it talks about preloading the Sherman... it seems to me that this would be redundant since I'm going to be preloading the main shaft... should I just use a gasket between the transmission housing and the Sherman Adapter plate, then use the shims that were previously there to preload the main from the rear bearing retainer? And, What's with the goofy tab on the Sherman adapter plate that prevents me from removing the lower front bearing retainer... Does anyone grind those off to prevent having to remove the adapter plate? As always, I appreciate you guys' input. Robert
