Back wheel question (Flat)
Redbanksdog
05-20-2007 17:39:03
I have a flat back tire on my 8n. How much does this wheel and tire weigh? Is it a two man job to load it in the back of the pickup? I"m not 20 years old anymore. Thanks for any help.
duey
05-20-2007 20:57:46
 Re: Back wheel question (Flat) in reply to Redbanksdog, 05-20-2007 17:39:03
I bought a good rim with a worn 11:00 - 28 tire on it from Palmer Fossum a few years back. It was loaded, and we knew it was. We got it slid in the back of a pickup and I took it home.
I suppose I had help loading it, but after that I was on my own. I got it unloaded and emptied the CaCL out... took the tire & tube off and welded on a valve stem protector and painted the inside of the rim.
Put it back together, no fluid, and loaded it up for the trip to the farm.
The major risk in handling tires is NOT EXPECTING them to be HEAVY. You can do lots of things as long as your avoid the surprises.
Don't get caught between a hard place and Iraq.
duey
Ultradog MN
05-20-2007 20:26:52
You too?
I pulled the tire off my tractor yesterday.
Took the 6 bolts off that hold rhe rim to the center. Mine aren"t loaded. The rim and tire don"t weigh over a hundred lbs is my guess.
Lean it against the tailgate and lift the bottom up into the pickup. Not too much for a guy to lift even if he"s three X 20 yo.
Mine had a big nail sticking out of the tire so I jacked the tractor up and pulled the tire.
After I got it off I noticed that the schrader valve was damaged. And it looked more like the culpret than the nail which I don"t think got the tube.
Going to go this week and buy a new screw in schrader valve. Hopefully that is the trouble and I wont have to break down the tire to patch the tube. Good Luck
old
05-20-2007 19:22:34
Air it up and then use 2 com-a-longs one in each corner of the bad and work it in that way BTDT many times
Redbanksdog
05-20-2007 18:48:36
I'm pretty sure the back tire has only air in it. I don't have a trailer. The tire shop is only 5 miles away. I'm thinking it might weigh about 150#.
Sean (TX)
05-20-2007 18:32:33
Pretty heavy. air it up and put it on the trailer and take it in. IMHO
john hunt
05-20-2007 18:31:41
any water in them if you water them there will be over 250 lbs it would just be wise to you to call out tire repair center to have repair them on the tractor
Dunk
05-20-2007 18:05:27
Well, does it have air or other in it?
It is nearly a 2 woman job to get me out of bed since I turned 50..
I can move a tire with water in it as long as I keep it standing, and prop it up.
No way could I put it in the back of a pickup.
With air in it I think I could.
