Order Ford 9N Parts Online
Ford 9N, Rear wheel bearings
Rick Himmelberg
05-21-2007 08:21:21
Is there a trick to removing the rear axle bearings to replace the inner and outer seals. I got the retainer off, but no amount of cussin' or prying will remove the bearings from the axle. The Manual says use a appropriate puller; even my Ford dealer says there's no easy way. HELP
Sean (TX)
05-21-2007 09:17:21
 Re: Ford 9N, Rear wheel bearings in reply to Rick Himmelberger, 05-21-2007 08:21:21
I paid a new holland dealer to do mine. They cut the bearings off with a torch...I supplied the parts and the replaced them. Machine shop with a big press could do it to.
gahorN
05-21-2007 15:15:10
 Re: Ford 9N, Rear wheel bearings in reply to Sean (TX), 05-21-2007 09:17:21
Hydraulic shop press. Take it down to NAPA or AutoZone and they'll probably do it for you. (Press the new ones on too!..Don't hammer 'em!!)
