15 min job on the kitchen table, yeah right?
Ratface
05-21-2007 13:52:33
Friday I went to install a set of points from one of the internet providers. The brass bushing inside the nylon part that rubs the cam had a lip on top and bottom. This was just enough to cover up the cotter pin hole. Filed off the lips. Pin goes in. Now the points will not close, maybe .050 was the closest I could get them. Next day go and get a set from napa. The hole for right hold down screw does not line up with the hole for screw. File and elongate the hole. A fifteen min. job turned into a two day frustration. Just ranting, where do you guys get points that are actually machined to some degree of tolerance?
Sean (TX)
05-21-2007 18:24:49
 Re: 15 min job on the kitchen table, yeah right? in reply to Ratface, 05-21-2007 13:52:33
Got my last set of points at NAPA. The set before that was TSC and it didnt come with the grease for the cam. So I forgot about putting it on. Points lasted 6 months.
TIP: copy this info in to a notepad file and save it for future use. Most napa parts guys wont know what to look for. I know I have tried.
Condensor: NAPA #FA200
Points: NAPA #CS35
Rotor: NAPA #FA300
Distributor Cap: NAPA #FA350
Sean (TX)
05-21-2007 18:26:49
 Re: 15 min job on the kitchen table, yeah right? in reply to Sean (TX), 05-21-2007 18:24:49
Im guessing its a front mount Dist. Common to tune up on kitchen table LOL
GB in MT.
05-21-2007 15:36:51
If you post what Make,Yr,& Model of tractor you are working on, I'd bet someone would be able to tell you where to get the part you need! I have never had any problems finding the points and or electrical parts, right here on this YT web site.
Post what ya got. Someone will help ya!!!
Gary
CENTAUR
05-21-2007 14:45:09
If you did not give the person more information about what you have for a distributor how could you get the right part?I do not have a clue.Sorry,give us something to work with.CENTAUR
ED-IL
05-21-2007 14:39:35
I got mine from this very website host, plus a distributor cap, distributor gaskets, and balast resistor, most recently.
gahorN
05-21-2007 15:13:44
 Re: 15 min job on the kitchen table, yeah right? in reply to ED-IL, 05-21-2007 14:39:35
Got mine from TSC 4 years ago and haven't touched them since. Still fires right up. (Front mount 9N)
Sean (TX)
05-21-2007 18:28:21
 Re: 15 min job on the kitchen table, yeah right? in reply to gahorN, 05-21-2007 15:13:44
Did yours come with the grease pill? Mine didnt and I over looked. Wore done the block that rubs on the cam.
