Radius Rods
Ramrod
05-22-2007 13:52:26
Why are they called Radius Rods? Are they actually formed on a radius? I always thought they were straight, but I begin to wonder lately...
Dan
05-22-2007 15:13:48
 Re: Radius Rods in reply to Ramrod, 05-22-2007 13:52:26
Could it be because they were designed to pivot outward in an arch when you adjusted the front wheel distance by extending the axle(?)
Dan
Ramrod
05-22-2007 20:37:46
 Re: Radius Rods in reply to Dan, 05-22-2007 15:13:48
OK, are they supposed to be straight, or bent in a slight radius bend?
Dan
05-23-2007 04:35:22
 Re: Radius Rods in reply to Ramrod, 05-22-2007 20:37:46
Straight. They only have the bend of you make contact with the front wheels to an immovable object while moving. Usually, the kingpin and bushing are worn and allow the axle to pivot downward when this happens and it bows the radius rods.
Dan
Ramrod
05-23-2007 04:46:17
 Re: Radius Rods in reply to Dan, 05-23-2007 04:35:22
another surprise from GT!
Dunk
05-22-2007 19:09:23
Exactly!!
Ross Pugh(NC)
05-22-2007 15:01:22
Being newly developed, they had to call the something, do you have a better choice? Why is a pencil called a pencil or a nail a nail. Just what it was named.
Dunk
05-22-2007 19:10:48
 Re: Radius Rods in reply to Ross Pugh(NC), 05-22-2007 15:01:22
Hey, Ross..
Do you know that every one of my chickens has a pecker... Even the hens...
Ross Pugh(NC)
05-23-2007 14:49:58
 Re: Radius Rods/Hey Dunk did you know? in reply to Dunk, 05-22-2007 19:10:48
Heey, Dunk, did you know most wives also have a pecker, they must have, how else would all the husbands be so henpecked?
TP
05-22-2007 14:11:20
Just a guess, but the later style after the 9n I beam is a formed structure with two radiused edges instead of square. It the two other sides were not flat, we would be calling them round rods. :-)
ENJOY...
TP
gahorN
05-22-2007 20:56:59
 Re: Radius Rods in reply to TP, 05-22-2007 14:11:20
They're called "radius rods" because that's the common nomenclature for such steering/suspension items. The rod reaches out to the front axle "radially" from the footpeg mounting point, and they perform the function of rods.
Bob
05-22-2007 22:57:51
 They're NOT just used on N's... in reply to gahorN, 05-22-2007 20:56:59
As Ga says, they are a generic suspension component.
