Order Ford 8N Parts Online
Should I buy this 8N
Adalai
05-22-2007 23:11:46
I'm thinking about buying an 8N to maintain 20 acres. I'll be keeping 2-3 as lawn, bushhogging 10 once a year, and the rest is woods. Also, I'd like to plow up about 1 acre of sod for a garden. Half the property is pasture gone to seed, so the first time around I'll need to take care of sumac, dogwood, and juniper saplings with up to 1" diameter.
There's one for sale a couple miles from my house. The previous owner had it converted to 12v and now it won't start without a jump, although I'm pretty sure I know why. (One of the spade connectors on the alternator isn't connected to anything. I don't remember whether it was the #1 or the #2. I do know that when you only have two wires connected to a three wire alternator, your gonna have a problem.) New radiator, new hydraulic pump on the hitch, no smoke, good oil pressure. The tires are pretty worn down with a hardy amount of weather checking. The price is $2500 and that includes a 5' bushhog.
So, I have two questions. Will an 8N do the job? And is $2500 a fair price for one like I described?
Thanks guys.
MUskie
05-23-2007 16:25:05
 Re: Should I buy this 8N in reply to Adalai, 05-22-2007 23:11:46
Yup, it will work for what you mentioned. That's where the N's are at their best .... plowing and mowing.
The price.... Ballpark for sure. Maybe just a tad high here in MI, maybe not.
If it doesn't start, that should give you some bargaining power.
My question... If it doesn't start, how do you know it doesn't smoke and the OP is fine???
Muskie
Buss
05-23-2007 11:35:39
One other thing you might want to consider is the price of new rims with the tires in the shape you say they are. I recently got a flat on a rear tire that had a good looking rim but after removing the tire and tube I found that the rim was rusted so bad on the inside that it couldn't be used. This might be more of the "case" if they are the "Old Style".
Jim.UT
05-23-2007 09:46:12
I agree 100% with everything said so far. In addition, you should click the link, read it carefully (maybe even print it out) and go look at the tractor again.
souNdguy
05-23-2007 07:08:56
It's deffinately ballpark.
Your issues will be battery and alternator.. one or both are bad.
Tires? How long witll these last?
If you can get any lower price.. i'd go for it.
Best bet is tires will hold air and go for 1-2 more years.. and battery is at least serviceable.. and alt just needs wire hooked up to #1 exciter then works.
Worst case is you need a new bat and alternator.. 200$, new tires all around and tubes 800-900$
So... if the tractor is in really good shape.. consider all of that. ( as long as the tires hold air.. pasture mowing should be ok.... I wouldn't go replace them till they were leaking... )
Soundguy
NTP
05-23-2007 05:29:04
$2500 would be a fair price if the tires were in good condition. You can figure 5 to 7 hundred dollars to replace the tires with new ones. Buying one of these old Fords ia always an adventure, as you may well find other problems that will cost you dollars to correct. If at all possible, have someone that knows these old Fords check it out for you if you are not familiar with the little quirks of these Ns.
Henry M
05-23-2007 05:27:31
I personally think the price is a little high. I bet he knows what the price of new tires will be.
He is als selling a problem that he has not been able to resolve.
I think 25 should get you good tires and a push the button and go.
My thoughts. I paid less than a grand for one that was solid, had good tires, but would not run. But that was crhistmas come early.
TheOldHokie
05-23-2007 05:23:13
Wouldn't be my first choice - wouldn't be my last either. A lot depends on your budget and the lay of your land. The 8N is a good mowing and tillage machine and has a low buy in price. But inadequate brakes and gearing make it a poor performer on hilly land. And sooner (likely) or later you're going to want a loader and the 8N just isn't a good loader machine even on flat ground.
If I had your job to do I'd shop prices on something with PS, Hi/Lo range transmission (prefereably with a diffy lock), live hydraulics, and possibly a loader before I made my final decision. You might be surprised what another $2000 will buy you.
JMO,
TOH
Marty 2N IL
05-23-2007 04:10:21
I use my 8N for about the same thing. It works great but I need to move my 2N over there so I spend less time switching from brush hog to finsh mower. 2500 around here might be a little high depending on condition. I gave 2200 for mine but it had new tires all the way around, almost all orginal right up to the lights.
Ken Crisman
05-23-2007 00:21:37
There's still a lot of 8Ns used to work small farms like you have .The asking price is about right with mower . Be sure to use an ORC on the PTO shaft when mowing . First thing I'd do after getting it home is change all fluids & replace the rubber shifter boot because that's where water gets into the system from rain/snow .Njoy & play safe . Let me know how it goes & if more advice is needed & send me pics . Good luck & God bless , Ken
