Carb question?
Tim in Tenn.
05-23-2007 20:06:58
I have a marvel sheibler carb. that i can't get the needle valve to seat.The float is adjusted right, and every thing is clean. I shut the gas off, but sometimes I forget and the air cleaner hose is full of gas.Doe's anyone have a trick to seat these rubber tip needles?
TooTall
05-24-2007 08:31:42
 Re: Carb question? in reply to Tim in Tenn., 05-23-2007 20:06:58
third party image
Smokey Mountain Knife works sells these screwdrivers for a very reasonable price. (12.99 for a 30 pc kit). Obviously you can make your own, but here they are ready made for you if you preffer. If you search their web page they have several other options if this isn't what you want.
RP-40-9n
05-23-2007 20:25:58
tim, i had one that i could never get to seat, so i put the old metal one back in. RP
Dell (WA)
05-23-2007 20:24:10
Tim..... ..would it surprize you to learn its NOT the rubber tip needle, its the 2-slot valve seat. You really haffta HONK-DOWN on it to seal BEHIND the valve.
I bought an el-cheapo squareshank WIDE-BLADE screwdrive that I HOLLOW-GROUND with grinder to fit the slotted valve seat tightly in BOTH NOTCHES. The square-shank allows me to use an crescent wrench for leverage so I can really "HONK" her down tight. You haffta "HOLLOW-GRIND" the blade to gitt a square side flatblade 'cuz iff'n you leave it normally "wedge" shaped, you will BUGGER yer valve seat slotts. Understand???
You can also get "hollow-ground" screwdrivers already ground, they are called "gun-smithing" screwdrivers. I have never found them locally 'cuz they are very special and have wooden handles. $$$ Gunnys gitt nutts about scratched screw-heads.
As to yer vicron-tip needle, you need to "polish" the rubber by "twirling it" around in the seat. You will end-up with a slight ring around the tip..... ..Dell
Poot
05-24-2007 05:41:48
 Hollow ground screwdrivers in reply to Dell (WA), 05-23-2007 20:24:10
third party image
This is what Dell is referring to. Notice the shape of the tips. They get a good "purchase" in the slot of the screw & as Dell says; you can really "honk down" on the screw.
