Manifolds tourque
9N13830
05-24-2007 18:39:27
Hello all going to install a new manifold on the 9n and would like to here where u-all have been setting your tourque wrench to make sure we have a good fit. thank you for your help
Dell (WA)
05-24-2007 19:35:21
 Re: Manifolds tourque in reply to 9N13830, 05-24-2007 18:39:27
According to my Boeing Engrs handbook, 7/16 BRASS-NUTTS are torqued to 27ft/lbs. Be certain to use "anti-sieze" on them. Brass-nutts are used so they STRIP when they are corroded and removed. That way yer studs stay in the block. Double check yer studs for 50ft/lbs torque before re-installation, you haffta use double-nutts to JAM together so you can torque the stud, understand? ..... ...Dell
8N'r--WI
05-25-2007 06:25:43
 Re: Manifolds tourque in reply to Dell (WA), 05-24-2007 19:35:21
Dell---I replaced a manifold on my 51 about 2 years ago. I seem to remember that somewhere in the archives it was recommended that the 2 middle bolts should be torqued first? Does it make much difference?
Tim
Dell (WA)
05-25-2007 08:11:37
 Re: Manifolds tourque in reply to 8N'r--WI, 05-25-2007 06:25:43
Tim..... ..starting yer torquing sequence from middle to OUT is standard technique; witness how yer 18-bolts cylinder-head pattern is laid out.
4-bolts of yer manifold, probably not, but it does allow compensation for "warp-page", if enny ..... .Dell
9N13830
05-25-2007 04:40:23
Thanks guys I will check the stud torque before I install this manifold
mad farmer
05-24-2007 19:08:15
I went with brass nuts so did not go too tight 10-15 lbs? Has not leaked for ca. 5 yrs.....
