Guys..... .heres a tip: lookin' fer a really good mechanic? check his secret stash of customized tools (bent, welded, ground, cut-off, modified, etc) Case in point..... I needed some very thin valve tappet wrenches to change a part. I carefully checked the "flats" dimension, 9/16" according to my dial caliper. Now its been 30yrs since I needed to adjust valve tappets and dang iff'n I can find that vinyl roll of el-cheapo tappet wrenches. So I'm rummaging 'round and find this 1/4" thick el-cheapo 9/16" open wrench. NOT part of my "Snap-on" set. So out with the angle grinder, and SPARKIES AWAY for 'nutter customized wrench. Finally gott it thinned to about 1/8" thick and it will fitt the gapp..... except.....it won't fit the "flats"..... .WTF??? Out with the calipers again..... flats are slightly wider'n 9/16"..... .its METRIC!!! 15mm. So NO, I ain't gonna grind my Metric Snap-On's neither. So now I'm searching for the word..... ...awe shoot? naw, AH goozeinntite? naw..... time-to-quit and go shopping tomorrow..... .thats the word....QUIT..... ..the bummed Dell
