Goatsie..... ..yer right, I am proud of yer wiring skills. Use that 2-terminal terminal block under yer ammeter for ALL yer wiring common interface junctions, including the SUPPLY to yer headlites switch. Q#1.....you probably had yer tranny in NEUTRAL when trying to rotate yer diffy with with yer tractor tires and the brake-drag on other side stopped the tire rotation. Iff'n it worked without yer tires, yer good to go. Q#2.....scratching noise could be bent/warped brake backing plate ...or... could be slightly too tite brake adjustment ...or... could be outta-round brakedrum ...or... last choice would be brake-springs wrong. I wouldn't worry about it unless you couldn't STOP. Q#3.....roundcan ignition coil polarity rule is (+) to (+); coil (+) to points which are POSITIVE GROUND iff'n yer battery (+) is connected to GROUND. Simple, eh? Since you report yer tractor is NOT like 6-volt factory, then connect yer coil (-) to distributor feedthru to points which is (-) ground 'cuz yer battery (-) is connected to ground for NEGATIVE GROUND. Would I change back to factory positive ground? Only iff'n I were sphincterly challenged. (and I ain't) Q#4.....ALWAYS use a terminal block, it keeps wires from danglin' and from shortin' OUT. terminal blocks are GOOD. Q#5.....NO RESISTOR, EVER!!! with real 6-volt roundcan coil in a real 6-volt battery system.
