GT Update - Fan Shroud too wide!?!
Ramrod
05-29-2007 07:56:05
Worked a bit on GT this weekend, got in the replacement Front Support, cleaned it up enough to check it out, now I got two bad ones, so Derek is sending me a guaranteed good one this time. Dropped the gas tank, peeked inside with match (just kidding, used flashlight) looks like new, so washed it outside in deep sink and reinstalled. Cleaned out the filthy sediment bowl and reinstalled with rubber gasket, got new fuel line and carb is rebuilt, so fuel systen should be done. So now it is time to mount new fan shroud on recently replaced radiator. Shroud is about 3/4" too wide! What gives? Is after market radiator suspect? Radiator does mount correctly, what am I missing? Shroud looks to be correct except for width.
Ramrod
05-29-2007 18:17:26
 Re: GT Update - Fan Shroud too wide!?! in reply to Ramrod, 05-29-2007 07:56:05
1. Grind off big chunk.
2. Beat on liberally with hammer.
3. Beat on liberally with big hammer.
4. Thread screw holes.
5. Install left side screws.
6. Use big pliers to warp to size.
7. Install long screws and pull in to shape.
8. Replace long screws with shorter screws.
9. Admire newly installed fan shroud.
10. Beat on some more to clear hoses.
11. Admire expert craftsmanship.
