Just curious...
Poot
05-31-2007 12:41:02
third party image
I was messin with my new ( to me ) '46N & noticed the badge was corroded, not painted. I used WD-40 & fine steel wool & cleaned it up. It doesn't appear to have ever been painted & has 2N stamped just below the Ford logo. It is also 1" smaller than the 8N badges. The badge seems to be made of aluminum, so the question is: were the original 2N badges painted or just polished? neither of my 8Ns have the model stamped on the badge..
don b
05-31-2007 13:53:38
 Re: Just curious... in reply to Poot, 05-31-2007 12:41:02
Poot....the badge had a deep dark blue background.The Ford in the center was chrome as well as the outside ring. don b
Randy(PA)
06-01-2007 10:14:59
 Re: Just curious... in reply to don b, 05-31-2007 13:53:38
The material of the 9N and 2N badges was only zinc die cast. There is no sign of chrome rims or script, rather the spec was clear lacquer over zinc P-65. The tiny 2N was in the depressed painted area below the Ford script, and was supposed to be covered with paint. There is no sign of there being a -B design of any other material. The 8N badges, tho, had a zinc die cast first version and a -B which was steel. These did have chrome outer rim and script.
Ramrod
05-31-2007 13:40:37
I think there was a -B suffix badge that was aluminum, but don't quote me.
souNdguy
05-31-2007 12:54:07
None o fthe other badges had a model designation. As yuo found out. the 2n was ont here to distinguish it from a 9n.. and 8n had a different badge anyway.
Can't help you on original finish..
soundguy
