Order Ford 8N Parts Online
which rearend fluid for 8n
arthur ward
05-31-2007 18:46:12
Ford MC-134D, gl1, gl3 or gl5
up nort in wisconsin...so cold in the winter for push n snow and 90 in the summer for field work.
which and why?
jdjunkie
06-01-2007 16:22:08
 Re: which rearend fluid for 8n in reply to arthur ward, 05-31-2007 18:46:12
walmarts gl/5 says it is safe for yellow metals
soundguy
05-31-2007 21:07:12
Your choice.. either the thin 134d oil.. or the thicker 90wt.
Thinner oil works better in the cold when you first start up. however may leak in a worn system..
thicker oil may take a bit to warm up to give good hyds response int he cold.. but generally makes the pump quieter and cuts down on leaks due to marginal seals or worm lift piston rings.
Gl3 is a good oil.. TSC carries some that is probably close to a 90w gl3 oil. gl4/5 is ok if you can find some that is yellow metal safe. ( quite a few are... )
Soundguy
