vented gas cap
9n13830
06-01-2007 07:38:33
well I cant get into the archives for some reason today so I will ask where to get a vented gas gap so I dont have to pull the hood till this winter.
I have looked on line and havent seen one that says vented. Thanks to every one that replies
Dan2N217688
06-02-2007 03:25:29
 Re: vented gas cap in reply to 9n13830, 06-01-2007 07:38:33
NAPA sells them a whole lot cheaper than $58.00. I dont know the part number. Just got to find a guy at the counter smart enough to look it up. When I had my tank lined, they covered up the vent hole. The guy that lined my tank called NAPA, and they had one on the counter waiting for me.
Scott PA
06-01-2007 18:06:37
Your local New Holland dealer still offers the free gas cap exchange program Ford came out with in 1986, just take your old cap, the model# and hand stamped serial# to the dealer, if they are a new dealer and know nothing about it tell them to refer to service bulletin# 1993/10-T2 and to note that the old cap does not meet current venting and spill requirements, there is a defect in materials, the new cap meets current venting and spill requirements so they get reimbursed. Keep the gas level below the bottom of the plastic neck of the new cap. Do not remove the cap when the engine is warm or hot.
9n13830
06-01-2007 19:14:53
 Re: vented gas cap in reply to Scott PA, 06-01-2007 18:06:37
Scott That seems like a great way to get a new cap. buying one will not happen, they want 58 bucks for it... so I will check out the exchange next week, Might just call them in the morning.
Thanks
RP-40-9n
06-01-2007 14:48:43
a drill with a small bit makes em vented instantly. RP
Mike Hunt
06-01-2007 14:47:24
It's so simple that, if you actually USE your tractor, you'll find that the loose gas cap will most likely vibrate off and your bush hog will eat it..... ...then you'll be back, asking where you can buy another one.
Dell (WA)
06-01-2007 07:51:01
Welp, yer local CNH (es-Ford) dealer sells a "vented" gascap. Meets OSH and EPA standards. ...or... just don't tighten yer gascap tite. Simple, eh?..... ...Dell
gahorN
06-01-2007 16:30:29
 Re: vented gas cap in reply to Dell (WA), 06-01-2007 07:51:01
Drill a 1/16 or 1/8" hold straight down thru that center rivet. (Do it on the work bench about 20 feet away from the gas tank.) ;Þ
