water pump problems
rich in n minne
06-01-2007 17:31:24
Hi Everyone.
I have been following this board for years but now have my own perplexing problem. My water pump went out on 48 8n. I drove it about 100 ft after the tell tale racket of a failed water pump. The engine was not hot but the coolant was quite low. I changed out the water pump and when I started it up, it was smoking and belching smoke out of the exhaust. The white smoke and antifreeze odor tells me that I am getting coolant in the combustion chamber. Any thougts out there on what may have occured. There was no sign of this problem prior to the changing out of the water pump. Thanks for your advise.
Rich
RP-40-9n
06-01-2007 21:51:31
 Re: water pump problems in reply to rich in n minnesota, 06-01-2007 17:31:24
rich, i got a feelin that your problem was not the water pump, but was actually the motor rattlin cause of water gettin in the combustion chamber, caused by a bad head gasket. puttin on a new pump would not cause the white smoke. RP
Dunk
06-01-2007 17:54:00
Time to do a compression test.
Hopefully just a head gasket.
