I was introduced to synthetic oil by a friend who works for a towboat company, shoving barges up and down the Mississippi River. He said that since they switched to synthetic oil, they NEVER, I repeat NEVER change the oil in their towboat engines. They do, however, change the filters annually. He gave me a case of synthetic for my car, but told me I would have to change it about once a year because, unlike towboat engines which are never shut down except for maintenance, a car engine gets hot and cool repeatedly, which causes condensation in the crankcase (and the fuel tank) and the condensation will pollute the oil. Tractors would be the same I think. The most noticeable difference in using synthetic oil in a car is a sometimes dramatic increase in gas mileage. It's simply a better lubricant than regular oil - slipperier - and causes less friction (and less heat). But I don't use it in my Model T or my 9N because of 2 things. One is that it finds ways out of the engine more readily, and leaves more spots on the floor, than regular oil. The other is that there are seals and gaskets in older engines that MAY not like synthetic oil. For the Model T and the tractor, I subscribe to the idea that you can't find any oil on any store shelf today, at any price, that isn't far, far better oil than you could buy at any price when the engine was new. The same with gasoline, by the way. So, go to WallyWorld, or Big Lots, or wherever you can get it cheap, and buy what you want. Your only question should be viscosity, and that choice has more to do with the age of the engine and your operating temperature range than anything else. Yes, Rotella T is good oil for a tractor. I use it because we buy it in 55 gallon drums with a pump on top, for use in our big generators. By the way, keep your gas tank full to avoid condensation, too. It's far better to fill it when you finish for the day, than before you start out the next day. Of course you're more tired, but think of the condensation you'll be avoiding in the tank! You do, however, need to be a bit more careful not to spill it on the hot engine than you would if the engine were cold.
