rattling
arthur ward
06-03-2007 17:35:09
49 8n that rattles somewhere up around the front of the gas tank. every fricken time i down throttle it sounds like its going to shake apart. all bolts are tight. anyone else have this issue?
Joe in MI
06-04-2007 13:31:43
 Re: rattling in reply to arthur ward, 06-03-2007 17:35:09
I had a nasty rattle in mine - turned out to be the top left springy thing that holds the top of the grille in.
Dan
06-04-2007 04:24:19
Not sure if you have lights on your tractor, but I found an annoying rattle with those little metal clips that hold the headlight wire to the bottom edge of the hood when I throttle down. They just are not tight enough.
Dan
Ramrod
06-03-2007 19:48:11
There are two anti rattle pads that clip to the fuel lines under the gas tank, got 'em?
Bruce (VA)
06-03-2007 17:50:16
Fuel line could be bumping up against the bottom of the tank.
Bob
06-03-2007 17:49:05
Fan hitting the shroud? (Worn out waterpump bearing?)
Dunk
06-03-2007 17:43:54
Yeah...??
But my latch is bad on my hood door...
arthur ward
06-04-2007 01:10:11
 Re: rattling in reply to Dunk, 06-03-2007 17:43:54
oh.LOL. i didn't know there were anti rattle pads for the fuel line. how stupid. why didnt hank just give a little distance between the fuel line and the tank? coulda saved a little money on pads and put it into a grease fitting for the steering box instead of that filler plug.
its not the water pump, its a new one on a new engine and it rattled before also. i'll double check the door also but i don't think that is it.
thanks folks
