Order Ford 8N Parts Online
Not Charging 6v pos gnd - '49 8n front mount
Ramrod
06-04-2007 17:11:53
third party image
OK guys, first time on a 6v system. GT is running and not charging. It was neg gnd, now it is pos gnd. I flashed the armature to field while it was running and nothing changed, did get a little spark. Ammeter is correctly wired, shows discharge when cranking, small discharge when running. This system was working correctly before rebuild and conversion back to pos gnd. See pic of voltage reg, which terminal is which?
Phil (NJ,AZ,Sask)
06-05-2007 09:47:54
 Re: Not Charging 6v pos gnd - '49 8n front mount in reply to Ramrod, 06-04-2007 17:11:53
Ramrod, Your two (2) bobbin (relay) regulator does not have Current Regulation. It was/Is used with a 3 Brush Generator.
Do you have a 3 brush GEN ?
The 2 Bobbin regulator will work with a 2 brush generator but if you ever have a "Shorted" load the GEN will be damaged (Smoke)
JMHO
souNdguy
06-05-2007 07:03:04
Boy you need some help.
You don't polarize an A circuit job like that when it is running.. and you never flash to the field on an A circuit regulator.
A circuits polarize ARM to BAT when the unit is not running.
B circuit gennies..like an NAA has polarize BAT to FLD.. and that CAN be done when running as that is the way it full fields also.
There is agood chance your regulator is smoked if there was any power on that armature...
School of hard knocks just got a 40$ tuition fee is all.. probably what your new regulator may cost.
Soundguy
Dunk
06-04-2007 18:20:56
See ifn this helps...
Link
Ramrod
06-04-2007 18:56:30
 Re: Not Charging 6v pos gnd - '49 8n front mount in reply to Dunk, 06-04-2007 18:20:56
Yeah, I finally got it, right there in front of me. It was hot today, brain drain set in. We had it wired right, so it goes to alt/starter shop tomorrow, he'll fix it on the spot. I could hear a bearing knock in the genny anyway.
Ramrod
06-04-2007 17:35:04
I'm looking for A, B, and C, what connects to what? Is A field or arm? Is C gnd? This pos gnd system is a bit strange when I get to VR circuit.
Jack-Illinois
06-04-2007 17:29:01
Top set = cutout - they are open and pull in as generator gets up to voltage
Bottom set = voltage regulation - they open up when generator reachs proper charging volatage.
(not open to look at more like a viberation of fast open close)
