Order Ford 8N Parts Online
Water temp on 8N?
Ramrod
06-04-2007 17:44:00
Can I add a water temp gauge to GT? Where would the sender go?
56Henry
06-05-2007 02:04:05
 Re: Water temp on 8N? in reply to Ramrod, 06-04-2007 17:44:00
I wanna thank Ramrod for providing the link & Hobo for the excellant write up & pics. Was planning on adding a temp gauge and that answers all questions.
If this board had smilies, I'd have a big one.(chuckle)
Ramrod
06-05-2007 05:44:38
 Re: Water temp on 8N? in reply to 56Henry, 06-05-2007 02:04:05
We're gonna learn this trick together. I'm headed out this morning to gather the parts for adding it to GT, and a voltage regulator, and a ballast resistor, and a rebuild on the genny, and whatever else pops up to surprise me on this 'quickie' front end rebuild ...
Hobo,NC
06-04-2007 18:42:56
Pert neer sure this izz the one I use. Use the 3/8" fit'n and not the 1/4 ore 1/2". EZ install have fun
TheOldHokie
06-04-2007 17:52:03
Been done many times before. My favorite method is drill and tap the cylinder head. Search for Hobo's step-by-step in the how-to's I think.
TOH
third party image
Ramrod
06-04-2007 17:51:03
 Never Mind Re: Water temp on 8N? in reply to Ramrod, 06-04-2007 17:44:00
I found Hobo's great article.
Henry M
06-04-2007 18:26:24
 Re: Never Mind Re: Water temp on 8N? in reply to Ramrod, 06-04-2007 17:51:03
Ramrod
Been there and done that. The most sensible mod I can think of.
Looking back, I would have done more searching for the guage with different fittings to go in the hole you are gonna drill and tap. I wound up with an extra guage because of lack of prior planning and purchasing what I need the first time. I found exactly what I needed at AutoZone
Ramrod
06-04-2007 18:30:37
 Re: Never Mind Re: Water temp on 8N? in reply to Henry M, 06-04-2007 18:26:24
I plan on visiting AutoZone tomorrow. It's across the street from the Alternator and Starter shop that will fix my 6v genny and VR for me.
DanL-Colorado 9N252085
06-05-2007 08:08:01
 Re: Never Mind Re: Water temp on 8N? in reply to Ramrod, 06-04-2007 18:30:37
That gray head with the green wire is mine. Took me, maybe 90 minutes to do the install, start to finish. It"s easy, so go for it.
